Collect a list of HDL parameters/generics in Tcl?
How can I collect a list of the VHDL generics (or Verilog parameters) of a VHDL entity (or Verilog module) from Tcl?
I am hoping to obtain a comprehensive list my top module's generics/parameters along with their values. Ideally this would even include generics/parameters that were not explicitly set by the user and instead just use their default values.
I know this must be possible since "write_vhdl" collects all VHDL generics of the top module and writes them as "attributes" in a VHDL netlist. For example, after elaboration of the following entity:
entity test is
  generic (
    G_GENERIC : natural := 1
  port (
    clk : IN std_logic;
end test;
"write_vhdl" will result in the following:
entity test is
  port (
    clk : IN std_logic;
attribute NotValidForBitStream : boolean;
attribute NotValidForBitStream of test : entity is true;
attribute G_GENERIC : integer;
attribute G_GENERIC of test : entity is 1;
end test;
So, somehow "write_vhdl" is able to determine the list of VHDL generics and write them to this VHDL netlist as attributes.
Any advice regarding how I can obtain this information via Tcl is much appreciated.
As a side note, is the source code for Vivado utilities like "write_vhdl" available somewhere? If I could see the "write_vhdl" source, I might be able to figure this out. I could not find this procedure's definition in my Vivado installation.
Thanks!
dbanks122
Re: Collect a list of HDL parameters/generics in Tcl?
Hi @dbanks122,
A similar query has been discussed in following forums post:-
https://forums.xilinx.com/t5/Vivado-TCL-Community/Get-generic-value-from-Tcl/td-p/780458
Have a look at it, let me know if it resolves your query.
Chinmay
Thank you for your response @chinmays! Unfortunately, that link (was broken, fixed here: https://forums.xilinx.com/t5/Vivado-TCL-Community/Get-generic-value-from-Tcl/td-p/780458) does not resolve my query for a few reasons:
  1. This method only works for submodules in an HDL hierarchy (not the top module of a design)
    • It requires use of "get_cells" to get the module to probe for properties
  2. This method only works if you already know the names of all of the generics
    • I would like to get a list of all generics set for VHDL module
This method does seem to give the values for all generics (even those which use default values and area not explicitly set).
