Visitor spolasa
Compiling vivado simulation libraries with Xcelium
Hello ,
When I tried to compile simulation libraries on Xcelium. It gives the errors below, can someone help how to fix it. Using Vivado 2018.2
Library 'unisim' compilation error(s)
xmvhdl(64): 18.09-s001: (c) Copyright 1995-2018 Cadence Design Systems, Inc.
xmvhdl_p: *F,NOLSTD: logical library name STD must be mapped to a design library [11.2].
Library 'unimacro' compilation error(s)
Re: Compiling vivado simulation libraries with Xcelium
Hi @spolasa,
Can you please try compiling the libraries in another directory after properly setting the environment variables ? Have you tried adding the include line in cds.lib file. can you please share the compile_simlib.log file to check.
Which version of IES are you using with which Vivado? Please refer the below Answer Record for supported third party simulators with Vivado:
https://www.xilinx.com/support/answers/68324.html
Thanks & Regards,
Sravanthi B
Hi @spolasa,
The error is indicating a missing of STD library mapping.
xmvhdl_p/NOLSTD =
In order for xmvhdl_p to operate, the host environment must have a
design library called STD, and this library must contain the packages
STANDARD and TEXTIO.
Do you see the file cds.lib generated in the compiled libraries location? This file should include the below statement at the beginning.
Ex: INCLUDE /tools/dist/xlm/18.03.005/tools.lnx86/inca/files/cds.lib
Also, in this location /tools/dist/xlm/18.03.005/tools.lnx86/inca/files you should be seeing the cds.lib file and it includes cdsvhdl.lib in the same directory. cdsvhdl.lib contains STD library definition.
DEFINE std ./STD
It seems like the tool is facing issues finding this library. Can you please make sure that you have set the environment variables  correctly ($PATH, $CDS_INST_DIR etc) and you have enough read write permissions to the Xcelium installation directory.
e.g.
tcsh
setenv CDS_INST_DIR /tools/dist/xlm/18.03.005
setenv PATH $CDS_INST_DIR/tools/bin:$PATH
bash
export CDS_INST_DIR=/tools/dist/xlm/18.03.005
export PATH $CDS_INST_DIR=/tools/bin:$PATH
Thanks & Regards,
Sravanthi B
Visitor spolasa
Hi Sravanthi,
I have set the CDS_INST_DIR and PATH variables and also noticed that tools.lnx86/inca/files/cds.lib includes cdsvhdl.lib
But I dont see INCLUDE /tools/dist/xlm/18.03.005/tools.lnx86/inca/files/cds.lib in cds.lib generated in the compiled libraries location. I assume this is auto generated file from the tool. Should we add it manually?
Hi @spolasa,
Thanks & Regards,
Sravanthi B
Visitor spolasa
Thanks Sravanthi , it worked after compiling in a different directory
