AzU
Connecting Zybo Board to Vivado HLx
Hey, I have a Zybo Board (Digilent), However, I have a question about connecting it to the Vivado HLx (2019.2), to see if there is actually a connection between it, so the board is connected to the computer.
How and where would I be able to see it?
At the start of the project, I have added the board as Zybo, but does it take anything else to make it connect and run?
philipwu
Hi @AzU
If you are referring to physically connecting the board to the computer via USB, you can refer to the documentation here: Zybo Board.
I believe there is a UART port on the board (see attached image)
Here's also a quick tutorial to connect the board in the Vivado project: https://www.youtube.com/watch?v=FBxsQUFMPMA
9.99 Udemy course on "Embedded Design with Zynq FPGA & VIVADO Tool": https://www.udemy.com/embedded-system-design-with-xilinx-zynq-fpga-and-vivado/?couponCo...
