Participant bwolfe
Connecting signals to ground in Vivado block design
I'm replicating a ISE tutorial design to Vivado. In that tutorial, some of the IP input signals are tied to "net_vcc" or "net_gnd" It's not clear how I would accomplish this in the Vivado Block Design IP integrator.
Any suggestions?
Re: Connecting signals to ground in Vivado block design
You don't assign it anything. The IP (may or may not) have pin tie off values already defined. There should be little 1's and 0's around the ports if they are defined (look at the resets or something).
If they aren't defined or you want to change the values, you must use a 'constant' block
www.xilinx.com
Two things
1) There are default tieoffs on ports (use the filters to enable them so you can see their values). Be careful with default tieoffs if you are building a hierarchical design.
2) Use a 'Constant' block
www.xilinx.com
Participant bwolfe
How do I "use the filters"? Is this something I set in Vivado? I can't find any features in Vivado with the term "filter" in it.
Sorry, I forgot what it was called ha!
www.xilinx.com
Participant bwolfe
Okay, I already had that open and all the boxes are checked. However, it's still not clear how to assign the default. I right click in the block design panel and Create Port...
In the popup, I give it a name, set the direction to input, and type to "other", but there is no default field, so I'm still missing something.
www.xilinx.com
Participant bwolfe
Okay, that's the detail I was missing. No little 1's or 0's, so i'll use the constant block.
Newbie noltmaster
How can I split the data_in_to_device[10:0] vector to individual signals
for example
data_in_to_device(0) ---> to input
data_in_to_device(1) ---> to input
data_in_to_device(2) ---> to input
 Screenshot from 2013-09-16 20:55:13.png
or is there an IP which performs the opposite of concat IP
Thanks!!
Yes, the 'Slice' block
www.xilinx.com
Visitor iamsim
Constant block is EXTREMLEY obfuscating - there is no way to name it like GND  or VCC.
How I can mark it someway to see, which value is set on it?
You can re-name the block in the 'properties' window
www.xilinx.com
Visitor iamsim
Thank you, it is realy helped.
But would be great to use some simpler way to connect pins to GND/VCC like another menu option near "Disconnect Pin"
Visitor babaraw
Have you solved the problem you mentioned?
Iif yes how?
Actually I want to split my 64 bit signal to two 32 bit signals but could not find any slice block to do that.  A 64 bit input is coming from outside world.
Thanks in advance.
/Babar
Satish
