Create IP Cores with TCL script and file reference
Hi there,
I would like to create some own IP cores for my master thesis. My work will later be used by a research assistant who is short in time for learning the vivado suite. Therefore I would like to make things easy for him.
In my project I decided to use own IP cores. To reproduce my actions I copy every tcl console output (which is a command) into a seperate tcl script:
if {[catch {current_project} result ]} {
} else {
puts "$result is open and will be closed!"
close_project
# Create the IP Core Wrapper for the whole managed cores
create_project -force managed_ip_project VHDL/IPCores/managed_ip_project -part xc7z010clg400-1
set_property target_language VHDL [current_project]
set_property simulator_language VHDL [current_project]
set_property target_simulator XSim [current_project]
# 							create the TDM8 RX IP Core
create_peripheral xilinx.com user TDM8_rx_AXIS 0.2 -dir VHDL/IPCores/managed_ip_project/../ip_repo
add_peripheral_interface M_AXIS -interface_mode master -axi_type stream [ipx::find_open_core xilinx.com:user:TDM8_rx_AXIS:0.2]
generate_peripheral [ipx::find_open_core xilinx.com:user:TDM8_rx_AXIS:0.2]
write_peripheral [ipx::find_open_core xilinx.com:user:TDM8_rx_AXIS:0.2]
set_property  ip_repo_paths  VHDL/IPCores/managed_ip_project/../ip_repo/TDM8_rx_AXIS_0.2 [current_project]
update_ip_catalog -rebuild
ipx::edit_ip_in_project -upgrade true -name edit_TDM8_rx_AXIS_v0_2 -directory VHDL/IPCores/managed_ip_project/../ip_repo VHDL/IPCores/ip_repo/TDM8_rx_AXIS_0.2/component.xml
set_property vendor ThomasMaintz [ipx::current_core]
set_property library TMAThesis [ipx::current_core]
set_property description {Converts the TDM8 Slave Receiver into the AXI Stream as a Master} [ipx::current_core]
add_files -norecurse -copy_to VHDL/IPCores/ip_repo/TDM8_rx_AXIS_0.2/src { VHDL/Code/PCM/pcm_package.vhd  VHDL/Code/TDM8/tdm8_package.vhd  VHDL/Code/TDM8/tdm8_trx.vhd} -force
set_property value_validation_list {32 24} [ipx::get_user_parameters C_M_AXIS_TDATA_WIDTH -of_objects [ipx::current_core]]
set_property widget {textEdit} [ipgui::get_guiparamspec -name "C_M_AXIS_START_COUNT" -component [ipx::current_core] ]
set_property value_validation_range_minimum 1 [ipx::get_user_parameters C_M_AXIS_START_COUNT -of_objects [ipx::current_core]]
set_property value_validation_range_maximum 64 [ipx::get_user_parameters C_M_AXIS_START_COUNT -of_objects [ipx::current_core]]
#               NOW COPY AND PASTE THE IP CORE VHDL FILES
#               FROM THE TDM8 DIRECTORY INTO THE CREATED
#               VHDL FILES!
update_compile_order -fileset sources_1
ipx::merge_project_changes files [ipx::current_core]
set_property previous_version_for_upgrade xilinx.com:user:TDM8_rx_AXIS:0.2 [ipx::current_core]
set_property core_revision 1 [ipx::current_core]
ipx::create_xgui_files [ipx::current_core]
ipx::update_checksums [ipx::current_core]
ipx::save_core [ipx::current_core]
close_project -delete
update_ip_catalog -rebuild -repo_path VHDL/IPCores/ip_repo/TDM8_rx_AXIS_0.2
Now I have 2 problems:
1.) All source files from the add_files command are copied into the IP core directory. I want them referenced so I have one single file to edit. How can I do that?
2.) If I create another IP core the old one vanishes from the IP catalog. Maybe I do something horribly wrong in the TCL script. Does anyone sees my mistake?
If you need more files / information just let me know ;)
Thomas
Observer yurifiore
Re: Create IP Cores with TCL script and file reference
Hi Thomas,
1) To add a file without copying it into your project, instead of specifying "-copy_to", try to use a simple:
-add_files -norecurse <path_of_the_file>
2) I suppose the error relies in one of the following:
What I suggest is to try executing the tcl commands line by line in the GUI and performing the update of the IP catalog manually through the GUI itself, then take a look at the tcl consolle
Cheers,
Yuri
Please accept as reply and give kudos if you found these info useful
Observer yurifiore
Hi Thomas,
Cheers,
Yuri
Thanks! Worked for me
