Downgrade Vivado drc check UTLZ-1 to warning
Hi there,
I have a design that after synthesis has a LUT utilisation of 104%, however I would still like to run implementation to see if after implementing the design the utilisation is still too high. Previous iterations of this design have removed circa 40% LUTs in the implementation stage.
The error messages advise i use the following command
set drc.disableLUTOverUtilError 1
to turn the error into a warning. But running this has no effect and the error  is still thrown.
I have also tried the following
set_property SEVERITY {Warning} [get_drc_checks UTLZ-1]
to try and override the severity of the drc check. But when I use
get_property SEVERITY [get_drc_checks UTLZ-1]
The severity is still set as "Error" and I cannot override this.
Is this a bug in vivado? Or am I not actually allowed to reduce over utilisation errors to warning?
Any advice would be fantastic
@lasthorizon711
Try using set_msg_config and see if it helps:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug835-vivado-tcl-commands.pdf#page=1585
 The link has examples at page 1589
--Syed
trying set_msg_config returns the warning: shouldn't be used to change the severity of drc/methodology checks
and advises the use of
set_property SEVERITY <NEW_SEVERITY> [get_drc/methodology_checks <ID>]
Hi, @lasthorizon711 ,
Please find your XX_opt.dcp in your run/impl_1 dir:
1. Open the XX_opt.dcp: open_checkpoint XX_opt.dcp
2. Execute the below command in the TCL CONSOLE:
    report_utilization -file util_opt.rpt
If the LUT utilization still more than 100% after opt_design, the place_design won't success.
I would still like to be able to run the implementation stage to view the final resource count if possible.
