Voyager
Voyager
ERROR: [Common 17-39] 'export_hardware' failed due to earlier errors.
Hi folks,
I have a ZYNQ design in Vivado 2013.02 that is implementing without problem.
I reach the point where 'write_bitstream' completes. I still have the implemented design open in the GUI, but when I try to Export the design to SDK, I get the following message:
There is nothing more in the LOG pane.
Any idea of what can cause this error?
Cheers!
Claude
Voyager
Voyager
Re: ERROR: [Common 17-39] 'export_hardware' failed due to earlier errors.
OK. Found the issue. The block diagram must be open.
May I suggest Xilinx to disable the <Export to SDK> menu item when no block diagram is open and/or no implemented design is loaded? Both of these conditions are needed for the export function to work.
Claude
Voyager
Voyager
Claude
i've got the same error
when triing to export hardware i get
ERROR: [BD 41-440] Hardware design cannot be exported until the IP Integrator design has been generated
in tcl console.
 Claude, What do you mean by "when no block diagram is open and/or no implemented design is loaded"
merci,n
Thomas.
Voyager
Voyager
Bonjour Fabien et/ou Thomas,
First, you shall right-click on the .bd file as shown in the attached file, and select both "Create HDL Wrapper" and "Generate Output Products...".
Second, youshall implement the design.
Third, you shall open the block diagram such that you see the schematic, and open the implemented design.
Fourth, you shall right-click again on the .bd file and select "Export Hardware for SDK...".
I hope that helps!
Sincèrement,
Claude
Thank you Claude,
 it worked !
 exactly this were the steps i dit to avoid the porblem (if it can help other persons)
First, right-click on the .bd file as shown in the attached file, and select both "Create HDL Wrapper" and "Generate Output Products...".
Second, implement the design.
Third,  open the block diagram such that you see the schematic, and open the implemented design.
Fourth, click on .bd to open it
Fifth,  right-click again on the .bd file and select "Export Hardware for SDK...".
Newbie galfonz
This seems to have been at least partly fixed in Vivado 2013.03.  I was having this same problem and found the answer here (thanks by the way).  I was able to get the hardware exported by making sure the block diagram was open and the implemented design was open.
It was not necessary to re-generate the wrapper or generate the output products again.
Scholar pedro_uno
Chevalier,  Merci pour la reponse. J'ai eu le meme probleme avec 2013.4.
DSP in hardware and software
Visitor yans6yans6
maybe you can   try   generate output product ,then EXPORT Hardware........................
Visitor bomel
I confirm, same problem with Vivado 2013.4.
And, if I insist, the GUI crashes after a while ...
Pierre
