01-21-2019 06:19 AM
I am getting an error while running the run_pr.tcl script used un UG947 (partial reconfiguration tutorial).
The error is:
## foreach config [sort_configurations [get_implementations "impl pr.impl" &&]] {
## #Override directives if directive file is specified
## if {[info exists useDirectives]} {
## puts "#HD: Overriding directives for configuration $config"
## set_directives impl $config
## implement $config
error deleting "D:/work/led_shift_count_us/Implement/Config_shift_right_count_up_implement\command.log": permission denied
ERROR: file command failed.
file delete -force ./Implement/Config_shift_right_count_up_implement
while executing
"error $errMsg"
invoked from within
"if { [catch $command errMsg] && !$quiet} {
append errMsg "\nERROR: $commandName command failed.\n\t$command\n"
error $errMsg
invoked from within
"if {[llength $log] > 0} {
if { [catch "$command > $log" errMsg] && !$quiet } {
puts "#HD: Command \'$commandName\' failed! Parsing $log..."
(procedure "command" line 41)
invoked from within
"command "file delete -force $resultDir""
(procedure "implement" line 63)
invoked from within
"implement $config"
("foreach" body line 7)
invoked from within
"foreach config [sort_configurations [get_implementations "impl pr.impl" &&]] {
if {[info ex..."
(file "./Tcl_HD/run.tcl" line 12)
while executing
"source $tclDir/run.tcl"
(file "run_pr.tcl" line 72)
Has anyone got the same error?
Luca
01-21-2019 07:37 AM
Double check that the file it wants to erase exists. if it does, check that you have permission to erase it.
If that still doesn't fix it, try erasing it with a system call to remove the file. Instead of having TCL force overwrite it (Linux rm Windows del]
That should prevent the script from hitting that issue.
01-22-2019 01:44 AM
Hi @evant_nq,
I have solved the problem by closing the TCL terminal and opening again.
At thatpoint the script runs without the previous issue.
Luca
