Visitor farnoodmb
Failed to get a license for 'xczu7ev-es2' for ZCU104 board when sourcing .tcl file in Vivado
Hi all,
I am trying to rebuild the overlay of the ZCU104 board in vivado using:
cd <PYNQ repository>/boards/ZCU104/base
source ./build_base_ip.tcl
source ./base.tcl
 but I am getting the following error when running te second command in Vivado Tcl console:
WARNING: [Common 17-301] Failed to get a license for 'xczu7ev-es2'. Explanation: The license feature xczu7ev-es2 could not be found.
Resolution: Check the status of your licenses in the Vivado License Manager. For debug help search Xilinx Support for "Licensing FAQ".
command 'ap_source' returned error code
while executing
"source [lindex $::argv 1] "
("uplevel" body line 1)
invoked from within
"uplevel \#0 { source [lindex $::argv 1] } "
INFO: [Common 17-206] Exiting vivado_hls at Mon Jan 28 17:06:58 2019...
ERROR: [HLS 200-70] License checkout unsuccessful. Make sure that a license is accessible or specify an appropriate one through an environment variable.
I have purchased the board directly from Xilinx and have the Vivado HLx edition 2018.3. I got the free license from the Product Licensing website from Xilinx. On the website, it is mentioned that with the purchase of the board, I will receive the Vivado Design Suite Design Edition locked for the node. But the lisence I received for free is for HL Webpack 2015 and earlier. Am I missing something or do I need a vochour to get the license for the board?
I am new to these board so any suggestion is appreciated.
Fred
Re: Failed to get a license for 'xczu7ev-es2' for ZCU104 board when sourcing .tcl file in Vivado
Hi @farnoodmb,
I think the issue is might be because of enbaling Beta Devices.
Please try this command enable_beta_device* through TCL console.
Hope the provided information will be helpful.
Raj Singh.
Visitor farnoodmb
Thanks Raj for a quick reply.
When I run that command, I get the following:
0 Beta devices matching pattern found, 0 enabled.
Among the licenses, I have the "xczu7ev" as a locked node, but not the "xczu7ev-es2".
I am not sure but there was suggestions to get the license by requesting it from
UltraScale Architecture Early Access Errata Lounge
I have just sent the request and waiting for the reply. Should I be able to get the  "xczu7ev-es2" license from there?
Farnood
Hi @farnoodmb,
I do not see any ES2 device for xczu7ev part in Vivado 2018.3. But 2018.2 and 2018.1 has it.
Provide full part name for xczu7ev.
Not sure.
hemangd
