shaikon
Voyager
Voyager
Filtering a TCL string
Vivado is able to print the current date to the console using the following commands:
set start [clock seconds]
puts "[clock format $start -format %D]"
The date that will be printed will be:
02/14/2020
Can you please post an example of a TCL script that would filter out the output of the above command to just print the day of the month (14 in this example) ?
14
richardhead
Google returned the answer probably quicker than you typed the message:
replace %D with %d
https://www.tcl.tk/man/tcl8.6/TclCmd/clock.htm
richardhead
replace %D with %d
