Voyager
Voyager
Help with .xml tag meaning
In my component.xml file for a custom IP I see there is a absolute path in the file.  This is the only one the rest are relative which is great.  What does this mean and why is this an absolute path?   See code snippet below:
    <xilinx:coreExtensions>
      <xilinx:supportedFamilies>
        <xilinx:family xilinx:lifeCycle="Production">artix7</xilinx:family>
      </xilinx:supportedFamilies>
      <xilinx:taxonomies>
        <xilinx:taxonomy>/UserIP</xilinx:taxonomy>
      </xilinx:taxonomies>
      <xilinx:displayName>AFE_v1_0_v1_0</xilinx:displayName>
      <xilinx:definitionSource>package_project</xilinx:definitionSource>
      <xilinx:xpmLibraries>
        <xilinx:xpmLibrary>XPM_CDC</xilinx:xpmLibrary>
        <xilinx:xpmLibrary>XPM_MEMORY</xilinx:xpmLibrary>
      </xilinx:xpmLibraries>
      <xilinx:coreRevision>2</xilinx:coreRevision>
      <xilinx:coreCreationDateTime>2019-03-01T19:34:45Z</xilinx:coreCreationDateTime>
      <xilinx:tags>
        <xilinx:tag xilinx:name="quartus.com:user:AFE_v1_0:1.0_ARCHIVE_LOCATION">c:/FPGA_Projects/Script_Testing/ip_repo3/AFE/ip_package</xilinx:tag>
      </xilinx:tags>
    </xilinx:coreExtensions>
Re: Help with .xml tag meaning
Does it bother you somehow?
I don't see any problem with absolute path. :)
The project infanstructure will handle it.
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
