luoxi213
How do I implement a non-project Tcl script example in UG894
As shown in the following picture, I don't know how to read those source files, who can tell me where to open them?
thank you
hongh
Oh, I see.
The example tcl script can just be referred to add your own source code. The source files mentioned in the tcl are not provided.
hongh
You can execute these command in TCL CONSOLE of Vivado GUI or execute as a tcl file.
%vivado -mode tcl -source XX.tcl
luoxi213
I tried your
% vivado-mode tcl-source XX. TCL
command, but still can't find the source file. This is what I want to find, but I don't know where it is
hongh
Please set the proper working dir before sourcing the tcl script. Or you can change the relative path to absolute path for the files in tcl script file.
Ex:cd abc/abc
luoxi213
My problem is that I don't know where the
./Source/ HDL /bftLib
folder is.Does it come with the software installation?
hongh
Oh, I see.
luoxi213
I am just a beginner, many questions may be very naive, thank you for your patience to answer
hongh
It’s normal to get stuck with some seemingly simple problems when you are just getting in touch with a new tool.
Please feel free to raise your doubts after some thought and searching.
