How to check the function of DSP48E2 by Tcl
I'd like to check whether the DSP48E2 is used as a multiplier or only an adder. How can I do it by using Tcl scripts?
Could someone give me a clue?
Re: How to check the function of DSP48E2 by Tcl
Hi @araongao2015,
You can use below command -
get_property USE_MULT [get_cells <hierarchical_cell_name_of_DSP48E2_primitive>]
If there is single DSP48E2 primitive in the design, this command will also work -
get_property USE_MULT [get_cells -filter {REF_NAME == "DSP48E2"}]
This USE_MULT property can have three possible values -
NONE : Primitive is used as Adder/Logic Unit
MULTIPLY : Primitive is used as Multiplier
DYNAMIC : The DYNAMIC setting indicates that the user is switching between A*B and A:B operations on the fly and therefore
needs to get the worst-case timing of the two paths.
Ashish
Hi @araongao2015,
Ashish
