How to do routing using Tcl scripts?
Dear all,
I am using Vivado 2016.1 and I would like to do the routing between two logic resources located in different slices and CLBs. I know that this routing must pass through different switch matrixes and logic resources and I know it is possible to do it via constraints definition. I have read UG894 and UG895 but they are so extensive and complicated ! Can anybody provide me a simple example of routing between two flip-flops to extend it for my own purpose?
P.S. : Previously this task was feasible in ISE FPGA Editor by Manual routing and I know it is possible in Vivado using scripts.
Kind replies are in advance appreciated.
Advisor evgenis1
Advisor
Re: How to do routing using Tcl scripts?
Hi @msdarvishi ,
Did you have a change to take a look at Vivado ECO flow in UG 904 on page 144 ?
It explains how to do custom routing. I personally find it much easier to do in Vivado than ISE.
Evgeni
Tags (2)
Hi @evgenis1
I think "manual routing" section at page-122 of https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug904-vivado-implementation.pdf will be helpful to you.
Deepika.
Dear @evgenis1 and @vemulad,
Both your suggestions are helpful thank you ! But, the way mentioned in UG904 (page 122 to 144) are for "Manual Routing". I am curious to know how can I write the relevant script in *.tcl file and run it and it will do the automatic routing between a source and a destination define in *.tcl file?
To make it simple, please see the simple routing between two flip-flops shown in the attachment. I can see the Direct routing constraint obtained by the tool as follows:
CLBLL_LL_BQ  CLBLL_LOGIC_OUTS5  WW2BEG1  ER1BEG2  EL1BEG1  BYP_ALT1  BYP_L1  CLBLL_LL_AX
Now, the question is that how can I import (or write) this routing constraint in *.tcl file and run it to do that routing automatically:? If this is possble, then we can control the routing path (which I think is feasible).
Hi @msdarvishi
After manual routing, save the design in vivado. This will write out the constraints to target XDC file (which you can use in TCL).
Deepika.
