How to include Verilog file that has path as well
I wonder if Vivado does handle including file with path, such as "`include "fifo_128/fifo128_stub.v". Synthesizer can do, but other IP integrator or project handling command does not.
-- For example --
I have a set of files under some path, say
/home/user/my_project/fifos/fifo_128/fifo128_stub.v
/home/user/my_project/fifos/fifo_256/fifo256_stub.v
/home/user/my_project/fifos/fifo_512/fifo512_stub.v
Then, I have a Verilog design file that includes those files as follows
[my_design.v]
`include "fifo_128/fifo256_stub.v"
`include "fifo_128/fifo512_stub.v"
module my_design ( .... ); ..... endmodule
When I try to packaing IP, Vivado complaines about cannot find the files.
I cerainly add the directory in 'Verilog options' of Settings: Verilog Include Files Search Paths, in which "/home/user/my_project/fifos" is listed.
Are soulutions?
Hi @andoki ,
Please check this link:
https://www.xilinx.com/support/answers/54006.html
Also try to give the whole path in `include command that should work.
Raj
