Advisor
Advisor
How to obtain synthesis options from a post-route DCP file
I'm trying to extract synthesis options used for a build from a given post-route DCP file. There are no project or log files available.
I know how to extract implementation options by running the following TCL command:
% report_property [current_run]
However, post-route DCP doesn't seem to contain any information about parent synthesis run.
Running the following command returns an error:
% current_run -synthesis
I'd appreciate any constructive ideas what else to try, or an expert opinion why it cannot be done.
Evgeni
Guide
Guide
I highly suspect that it is not possible to do what you are asking.
The synthesis properties affect the synthesis run. Once the run is complete, the result is a .dcp file, which is mostly the edif netlist and some constraints. Any properties associated with the synthesis run are now irrelevant - there is no reason for them to be stored with the design. Furthermore, there is no "place" to store them - they are not part of the netlist or the constraints...
Avrum
Guide
Guide
Avrum
