Lambert_Yu
How to remove one custom property for one design?
   I am facing one problem, I set one custom property for current_fileset, but I don't find one tcl command to let me remove this property from current_fileset. I try reset_property, but it said that it cannot support for this custom property. And I don't find any other command to do this thing, could someone help resolve this problem or provide me some idea? Thanks!
Brs,
Lambert
hongh
What's the type of the property you created? Have you set the default value?
Can you try to set an empty value for the custom property, which can work as reset_property.
