How to upgrade IP definition of TCL file
Hello
I am new with vivado and FPGAs, so i am working on "ZedBoard - HDMI Display Controller Tutorial".
My problem is when I add external IP (zed_hdmi_display moudle) using Tcl Console, there is error in VDMA pin because the TCL file work with vivado 2013.4 and my verson is 2018.2, So how to upgrade this file to be fulfilment with my verson please?
TCL file, error window and blockdiagram are attached
thank you for your help
Tags (5)
Re: How to upgrade IP definition of TCL file
ERROR: [BD 5-390] IP definition not found for VLNV: xilinx.com:ip:axi_vdma:6.2
The error is caused by  set axi_vdma_0 [ create_bd_cell -type ip -vlnv xilinx.com:ip:axi_vdma:6.2 axi_vdma_0 ]
In the new version Vivado, the IP has been upgraded to version 6.3 from 6.2.
The command should be modified accordingly:
set axi_vdma_0 [ create_bd_cell -type ip -vlnv xilinx.com:ip:axi_vdma:6.3 axi_vdma_0 ]
Thank you so much it's working now with my verson,
In addition, I upgrade:
1- [ create_bd_cell -type ip -vlnv xilinx.com:ip:xlconstant:1.0 gnd ] to [ create_bd_cell -type ip -vlnv xilinx.com:ip:xlconstant:1.1 gnd ]
2-  [ create_bd_cell -type ip -vlnv xilinx.com:ip:v_axi4s_vid_out:3.0 v_axi4s_vid_out_0 ] to  [ create_bd_cell -type ip -vlnv xilinx.com:ip:v_axi4s_vid_out:4.0 v_axi4s_vid_out_0 ]
3-[ create_bd_cell -type ip -vlnv xilinx.com:ip:xlconstant:1.0 vcc ] to [ create_bd_cell -type ip -vlnv xilinx.com:ip:xlconstant:1.1 vcc ]
in attach the TCL file after modified it, which now fulfillment with new versons of vovado.
Thank you
