Invalid property name 'platform.board_id' in TCL VIVADO bd project setup
Hello, experts. I am a newbie to this FPGA community so this might be a very basic question.
I am sourcing my colleague's TCL shell script to create a block-design.
The relevant part of the shell script is attached on this thread.
In the process of it, I get this error message that claims there is no property name for 'platform.board_id'. It's where it specifies the FPGA ID, and it seems ok to me, but it gives me this error message.
ERROR: [Common 17-142] Invalid property name 'platform.board_id'.  Please use the 'list_property' command to find properties supported by the target 'project' object.    while executing
"source scripts/cabletester.tcl"
After commenting out the line, the shell script obviously crachses with message that .bd file does not exist. Could someone explain and help me with the issue?
Thank you!
Hi @sk16t
I am quite sure you are not using the same vivado version as your colleague. The platform.board_id parameter did not exist in some old versions of vivado. For sure it is in vivado 2020.1 but this is not in 2017.4 (I only tested with these 2 versions).
Make sure to use the same vivado version as your colleague else you might get other issues if the script is not compatible with multiple versions
Hi @sk16t
