petdsp
Is it possible to change vhdl top module generic parameters in tcl scribe file?
I have a vhdl project, top module has some generic parameters to define diffence behave.
I can change the generic parameters before synth in synth GUI,
Is it possible to change vhdl top module generic parameters in tcl scribe file for better management?
viviany
set_property -name {STEPS.SYNTH_DESIGN.ARGS.MORE OPTIONS} -value {-generic MY_MACRO=my_val} -objects [get_runs synth_1]
Is this something you need?
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
hongh
Example to change the generic parameter with tcl command:
set_property -name {STEPS.SYNTH_DESIGN.ARGS.MORE OPTIONS} -value {-generic "tt=6"} -objects [get_runs synth_1]
viviany
-vivian
petdsp
That's exactly what i want. Thanks.
