marsmoon
Is there a tcl command to read the .xcix directly in non-project mode?
  I'm looking for an tcl command in non-project mode, which is to read the ip container files(.xcix) directly into memory.
  But I didn't find it. Only way I can do is to extract_files the .xcix and then read_ip in my tcl script.
  Is there a such tcl command to read .xcix directly?
viviany
read_ip can also work with .xcix file.
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
rshekhaw
viviany
-vivian
