juanelete
JTAG to AXI tcl
Hi there,
I am using the JTAG to AXI master core and I would like to know if there is a way to access to the core without using tcl commands, that is, some kind of driver. If not, it is possible to look into the code of the tcl commands to try to build a driver in C or python for example?
Thanks in advance.
Juan.
pratham
@juanelete Did that help?
-Pratham
pratham
@juanelete No, it's not possible. You must use tcl commands.
-Pratham
pratham
-Pratham
juanelete
So, where can I find information about read and write registers from my design via JTAG in a Zynq 7000?0
pratham
Here
https://www.xilinx.com/support/documentation/ip_documentation/jtag_axi/v1_2/pg174-jtag-axi.pdf
-Pratham
