List IPs from a repository
I add an IP Repository to my project. I want to list all IP available in it. I found "get_ipdefs"  it looks like this one list all ip available in IP catalog. Which command should i use to list all ips from a specific repo using path i get from "get_property ip_repo_paths [current_project]" ?
I found a solution by myself. If you have any better please tell me.
First define a variable to store the path of your repository :
set repo_path [get_property ip_repo_paths [current_project]]
make a loop on get_ipdefs command and use a filter with the first variable :
foreach n [get_ipdefs -filter REPOSITORY==$repo_path] { puts "$n" }
This solution works only if you have one repository. For more repo you have to store all repo path in an array and loop on it.
