05-18-2017 01:51 PM
I downloaded and unzipped the XAPP1161 distribution folder to my C: drive
C:\xapp1161
Check the directory
Directory of C:\xapp1161
05/18/2017 04:16 PM <DIR> coefficients
05/18/2017 04:16 PM <DIR> golden_data
05/18/2017 04:16 PM <DIR> hdl
05/18/2017 04:16 PM <DIR> ip
05/18/2017 04:16 PM <DIR> ise
05/18/2017 04:16 PM <DIR> matlab
03/18/2013 01:38 PM 6,743 readme.txt
05/18/2017 04:16 PM <DIR> sysgen
05/18/2017 04:16 PM <DIR> vivado
Then I tried to build the project using the Tcl file.
At the Tcl console I first change directory to the location of the Tcl file.
Remember to flip the slashes to forward slashes!
cd C:/xapp1161/vivado
Then I enter the command to build the project:
source generate_vivado_project.tcl
ERROR: [Coretcl 2-1133] Requested IP 'xilinx.com:ip:fir_compiler:6.3' cannot be created. The latest available version in the catalog is 'xilinx.com:ip:fir_compiler:7.2'. If you do not wish to select a specific version please omit the version field from the command arguments, or use a wildcard in the VLNV.
I then edit the Tcl file to change the listed references from 6.3 to 7.2
I send a close_project command to the Tcl console
I run the source command again
# set_property -name CONFIG.component_name -value {tx_fir} -objects [get_ips tx_fir]
WARNING: [Vivado 12-3523] Attempt to change 'Component_Name' from 'tx_fir' to 'tx_fir' is not allowed and is ignored.
# set_property -name CONFIG.coefficientsource -value {COE_File} -objects [get_ips tx_fir]
ERROR: [IP_Flow 19-3460] Validation failed on parameter 'Coefficient File (Coefficient_File)' for Please select a COE file to be loaded.
. IP 'tx_fir'
INFO: [IP_Flow 19-3438] Customization errors found on 'tx_fir'. Restoring to previous valid configuration.
ERROR: [Common 17-39] 'set_property' failed due to earlier errors.
while executing
"rdi::set_property -name CONFIG.coefficientsource -value COE_File -objects tx_fir"
invoked from within
"set_property -name CONFIG.coefficientsource -value {COE_File} -objects [get_ips tx_fir]"
(file "generate_vivado_project.tcl" line 29)
Above where it says to enter a COE file to be loaded, how do I do that?
An example COE file is provided in the C:\xapp1161\coefficients folder
The filename is: channelizer_8.coe
The full path and filename is: C:\xapp1161\coefficients folder\channelizer_8.coe
01-18-2019 08:43 AM
Ran into this same problem using Vivado 2016.4. I managed to fix it by setting both COE file properties simultaneously using set_property -dict (and also changing a couple other config values to options that are valid for newer versions). I've attached the fixed version that works for 2016.4 to this post.
