Problem with Makefile and vivado
I have a project with Makefile, using vivado flow and targetting Kintex7.
The Makefile is written by someone else.
When I try to "Make synth", it gives me this error:
make -C ../microblaze netlist libs
make[1]: Entering directory `C:/JEFFL/Projects/vivadoproj/syn/microblaze'
make[1]: Nothing to be done for `netlist'.
make[1]: Nothing to be done for `libs'.
make[1]: Leaving directory `C:/JEFFL/Projects/vivadoproj/syn/microblaze'
#- Vivado Synthesis...
vivado -mode batch -source vivadoproj_synth.tcl -tclargs "XST" vivadoproj xc7k160t-fbg676-2 edkBmmFile.bmm _synth
WARNING: $XILINX contains multiple entries. Setting
$XIL_PA_NO_XILINX_OVERRIDE to 1.
WARNING: $XILINX_EDK contains multiple entries. Setting
$XIL_PA_NO_XILINX_EDK_OVERRIDE to 1.
WARNING: $XIL_PA_NO_XILINX_OVERRIDE is set to 1.
When $XIL_PA_NO_XILINX_OVERRIDE is enabled
$XILINX, $MYXILINX, $PATH, and $LD_LIBRARY_PATH must
be manually set.
WARNING: $XIL_PA_NO_XILINX_EDK_OVERRIDE is set to 1.
When $XIL_PA_NO_XILINX_EDK_OVERRIDE is enabled
$XILINX_EDK, $PATH, and $LD_LIBRARY_PATH must
be manually set.
WARNING: c:/Xilinx/SDK/2013.2/lib/lin does not exist.
WARNING: c:/Xilinx/SDK/2013.2/bin/lin does not exist.
ERROR: c:/Xilinx/Vivado/2013.2/tps/lnx32/jre does not exist.
Vivado is unable to locate a valid installation of JAVA. PlanAhead is necessary\n
for Vivado to run. Please contact customer support for assistance.
My environment is windows, i don't know why it's looking for linux directories.
One more weird thing, If i run it from the command line, i.e just type
It runs through without any problem.
Any ideas, suggestion?
Thanks, guys!
Jeff
Re: Problem with Makefile and vivado
Check whether the $XILINX_EDK, $XILINX environmental variables are set. To check right-click on My Computer --> select Properties --> Click on Advance System Settings --> click on Enviornmental Variables (in Advanced Tab).
Also, where are you running this make file?
Teacher muzaffer
did you source your X:\Xilinx\Vivado\yyyy.xx\settings32.sh script before running make ?
Visitor binupr
I am having the same problem currently when I am trying to run XAPP1167. I manually set the Xilinx and Xilinx_EDK environment variables. Software version is Vivado 2014.4
Participant fsanchezfernandez
Did you find a solution?
I did, but I don't remember ... how there's something to do with linux/windows ... it's thinking it's in linux shell
I did, but I don't remember how ...  there's something to do with linux/windows ... it's thinking it's in linux shell
Chech your PATH environment variable, it should be looked like "c:/Xilinx/Vivado/2013.2/bin:XXXXX", so 'vivado' executable can be found by command line interface, then than command works fine; but it can't found by Makefile.
So set PATH like "/c/Xilinx/Vivada/2013.2/bin:XXXXX", then Makefile works fine.
I use mingw, and set PATH in $MIN_GW/msys/1.0/etc/profile.
