Project re-created from TCL script fails to compile.
I exported project TCL file with Write TCL command not not including any options (all unchecked).
Then I changed project name and some paths inside teh TCL and recreated the project.
It opens OK but any action has error:
[BD 41-1273] Error running init TCL procedure: can't read "auto_set_param_list": no such variable adi_auto_assign_device_spec Line 18
I can't find what is missing.
Michal
Re: Project re-created from TCL script fails to compile.
Hi, @mmisiek75 ,
Which version of Vivado are you using?
Could you attach your tcl script generated?
I'm using Vivado 2018.3 and unfortunatley I can't attach TCL file as it is propetiary.
@mmisiek75
Open the TCL file and check for the proc "auto_set_param_list" which is failing with error. I created the project TCL for a sample project containing BD at my end and I do not see any proc with name auto_set_param_list.
What happens when you do not change the project name and paths?
--Syed
So my problem is that I renamed the top directory of project couple of times and somehow project generated from TCL is still referencing IP from old name of top directory is not existing. But I don't have error with paramter missing.
If I don't modify the TCL file everythign seems to work fine (export TCL without sources was a key).
I would like to change project name and repository location so I can check it into GIT how can I do it ?
