tsung
RLOC_ORIGIN physical constraint is not honored from VHDL code
In order to physically constrained my design using RLOC/RLOC_ORIGIN. Following are the VHDL code from my top level modules
attribute RLOC_ORIGIN: string;
attribute RLOC: string;
attribute RLOC of SLICE_X1Y0: label is "X0Y0";
attribute RLOC of SLICE_X1Y2: label is "X0Y2";
attribute RLOC_ORIGIN of SLICE_X1Y0: label is "X1Y0";
Two instances "SLICE_X1Y0" and "SLICE_X1Y2" which has the name equal to the SLICE coordination that I intend to place. However, when I checked the design from GUI, it seems to me the RLOC constraints was honored but not the "RLOC_ORIGIN".
I use the "Vivado" version 2018.3 and the target device is "xc7s100fgga676-1"
Following is the screen dump of the design, as you can clearly see those 2 design instances are not located at the bottom/left corner as they should be.
richardhead
IIRC, Vivado does not accept constraints written in HDL code. You will need to apply RLOCs as part of the project in constraints.
tsung
Thanks for the help. Can you point me some document in order to constraint in the project.
richardhead
OK - I was wrong - it appears it should be possible. But it needs to be applied to signals - you appear to be trying to apply it directly to entities?
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug903-vivado-using-constraints.pdf
tsung
This is what I do following this document.
In the page 167, I applied the "RLOC_ORIGIN" at the particular cells as indicated by this document. Then, I found this issue which RLOC_ORIGIN is not honored.
tsung
After the design is synthesized, the .dcp is reading in, there is this "critical warning" which is confused to me. [Constraints 18-432]. Vivado seem to look for "RLOC_X0Y0" which does not exist on my design.
richardhead
Is it possible is was removed during synthesis?
I notice you are applying the attribute to a label - can you post the original code?
tsung
Thanks for helping.
Yes, the constraint is removed during synthesis. I am uploading my design files into this ticket. Please find the tar file - rloc_origin_issue.tar.gz. There is a script in the test case - run_vivado. There is one blackbox cell definition under directory "slice/plb.edf".
