cyril.francois
Read block design
I'm trying to create a script in Non-project mode to build my project. I'm working on vivado 2016.2.
I want to "read" my block design like read_vhdl to synthesis it.
Hereafter an extract of my script :
# Read Top FPGA file
read_vhdl -library work $top_sources_dir/top_zynq.vhd
# Read block design
generate_target all [get_files $lib_xilinx_dir/block_design/block_design.bd]
read_vhdl -library work $lib_xilinx_dir/block_design/hdl/block_design_wrapper.vhd
When I run it, it succeed to read the top_zynq.vhd but can't read the block_design.bd
The full script is in attachement
prathikm
Hi @cyril.francois,
I guess for reading one or more IPI design files read_bd can be used or scoping through write_bd_tcl can be used. UG835 (link) page. 1111 and 1742.
Prathik
Don't forget to reply, kudo, and mark the appropriate post as 'accept as solution'.
prathikm
Hi @cyril.francois,
Prathik
