Return code: 139
Vivado break after 10min without any log error. (just: Return code: 139)
I have complete run without any problem with the same configuration but one module is black boxed.
Utilization ~10%
When I include RTL version of this module that was black box before: compile, pre-map and map is done and Vivado start running and crash after 10min.
Board: Virtex UltraScale XCVU400
Vivado: 2018.3.1
Any idea what can be the problem?
Re: Return code: 139
@milosdinic
Can you share the project to reproduce the issue at our end? I have sent you a private message from ezmove (ftp).
If the project cannot be shared then share the log files here.
https://www.xilinx.com/support/answers/55854.html
Also run the following command in Vivado TCL console and share the generated xinfo.txt file.
report_environment -file ./xinfo.txt
--Syed
