Run Tcl script on Vivado exti or on project close
Hi all,
quick question, I wasn't able to find the answer anywhere so I hope someone help me here... My question is.. is there any way how to set a TCL script call when Vivado is about to exit (I hit the cross) or at least the project is closing? Something like the Vivado_init.tcl which needs to be placed in the certain Vivado folder but for closing?
Thanks a lot guys
Visitor xromka
Re: Run Tcl script on Vivado exti or on project close
You can hook any Vivado commands  using standard TCL technic. Simple add to Vivado_ini.tcl
### Hook of "close_project" procedure
if {[llength [namespace which {close_project_}]]==0} {
  rename ::close_project close_project_
  proc ::close_project args {
    puts "Hook of close_project"
    do_something_before_closing_project ....
   uplevel 1 ::close_project_ $args
proc do_something_before_closing_project {..} {...}
Good luck.
Hi @bartiko ,
There is no such feature as of now which can help to run script upon clicking 'exit' button or closing project.
I think closest workaround for you would be separately sourcing script just before close_project command (if you are using tcl script) or using tcl hook script (tcl.post) if you are using GUI flow. More about hook scripts -
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug894-vivado-tcl-scripting.pdf (page #21)
Ashish
Hi @ashishd
Thanks for replay. This looks usefull. But Is there any STEPS.ClOSE_PROJECT, or something like that? cannot find anything like this so far...
thanks a lot
Hi, @bartiko ,
Maybe you can try to customize your own commands with a new ICON and "exit" command is the last command.
Example tcl
puts "tt"
exit
1. Tools -> Custom Commands -> Customize Commands...
2. Create your own command and point to your tcl script.
By clicking the new ICON in toolbar, you can run your own commands and then exit Vivado.
Visitor xromka
Good luck.
@hongh  and @xromka
thanks a lot for suggestions. I'll try and let you with results :)
thanks alot once more
@xromka Thanks for sugestion. This works the most elegantly :)
