Akhil_Kodari
Run tcl commands in vivado TCL chell using python
I'm trying to automate resetting FPGA using python through TCL commands. Started vivado in TCL mode and gave tcl file as source to load bit file. After loading bit file again I want to run tcl file which has commands to reset FPGA. Please address how to do this.
python code snippet:
import os
import tkinter
r=tkinter.Tcl()
os.system('vivado -mode tcl tcl_file.tcl')
r.eval('source reset.tcl')
Here I used tkinter module to use tcl shell in python, but this is not working the way it is expected.
jbeckwi
You need to make sure to specify -source when you call the TCL script.  Without '-source' Vivado is launching in TCL mode but expecting a project with an .xpr file extension.
Jon
Akhil_Kodari
Sorry, that's a typo, my system call has '-source'.
os.system('vivado -mode tcl -source tcl_file.tcl')
richardhead
tcl mode is meant as interactive tcl mode. Is there any reason you're not using batch mode?
Akhil_Kodari
When working in batch mode, the Vivado tools exit after running the specified script, but I still need Vivado to run after script execution.
