Running TCL script from Shell script
Hello I need to run vivado in tcl mode within a linux shell script. I can do something like that
#!/bin/csh -e
vivado -mode tcl -nojournal -nolog -notrace -source syn.tcl
echo "going to rest of shell script ...."
my question is: I need to cause this script to stop running if vivado encountered a problem during synthesis operation.
i.e If the command "vivado -mode tcl -nojournal -nolog -source syn.tcl -notrace" got an error, I don't need the command "echo "going to rest of shell script ...." to be executed
So is there a way to get a return value from vivado command
Thanks in Advance
Voyager
Voyager
Hey @moibrahim,
#!/bin/bash
vivado -nolog -nojournal -notrace -mode batch -source syn.tcl
echo "return code $?"
... will show you the return code, where '0' means success and everything else in an error.
Note that you can also chain commands like this ...
vivado -mode batch -source syn.tcl && echo "success" || echo "failed
... or if you want to do more than a single command ...
vivado -mode batch -source syn.tcl && {
   echo "success."
   echo "all done."
   echo "error."
   echo "aborted."
Hope this helps,
Herbert
-------------- Yes, I do this for fun!
Voyager
Voyager
Hey @moibrahim,
#!/bin/bash
   echo "success."
   echo "all done."
   echo "error."
   echo "aborted."
Hope this helps,
Herbert
Thanks Herbert .. this really helped
Voyager
Voyager
You're welcome!
All the best,
Herbert
