Running the TCL console from cmd
I'm trying to automate a process where I am calling different Vivado tcl functions (write_project_tcl for instance) and a Python script (to automatically modify the tcl script generated by the write_project_tcl function). I've tried to write a batch file that would first call the Vivado function and then run the python script, but the function write_project_tcl is unknown from Windows and it can be only run when using the Vivado tcl console. Is there a way to run this console directly from the cmd prompt/use some Vivado functions within a batch file? Or is it possible to run a python script from the tcl console?
I have found a way to solve this issue by simply updating the environment variable 'path' so it contains the following path "C:\Xilinx\Vivado\2016.4\bin" which is obviously where Vivado is installed on my computer. Then it is possible to open a Vivado tcl console (with all vivado commands available) from the cmd prompt using something syntax like this :
vivado -mode tcl -write_project_tcl
It is also possible to run a python script from the Vivado tcl console using the following syntax:
exec python ./filename.py
Hope this helps someone else!
Hi marcel42,
  I meet the same problem in ISE, but follow your step I still can not solve the problem. Do you have any suggestions? Thank you!
Maybe you can try the below steps:
1. Set the ISE environment:
C:\Xilinx\14.X\ISE_DS\settings64.bat
2. Launch ISE in TCL mode:
xtclsh XX.tcl <options>
Hi hongh,
Actually I had tried that way, but I don't know how to operate the settings64.bat file and where to run the xtclsh. Would you mind giving me some more specific details? Thank you!
Hi, @yf201306 ,
Both commands can be executed in DOS Terminal(Windows).
Thank you, perfectly solved my problem!
