TCL command for exporting address for IP blocks in PL
Is there a way to export using TCL , the addresses shown in Address Generator  for IP blocks in Programmable logic in Vivado.
I am using Zynq MPSoC and for IPs in PL, I am interested to get their base addresses for my verification env.
It will be helpful if I can generate them using a script
BR
Bhanu
Re: TCL command for exporting address for IP blocks in PL
Hi @bhanu27 ,
Address map from an existing design can be exported to .csv file using following tcl command:-
assign_bd_address -export_to_file <path_to_the_csv_file where memory map is to be written>
Please refer to UG994-page 94- Importing and exporting address map from address editor
~Chinmay
Hi @bhanu27 ,
~Chinmay
