ldm_as
TCL proc -> sending arguments to a proceedure by name
Hi All,
Is it possible to send arguments to TCL proceedure by name and not by order?
I mean if the proc is as following:
proc comp_rtl_lst {RTL LST UNIT LIB} { #* Compile RTL
echo "-> @comp_rtl_lst";
set FILE [open "${LST}/${UNIT}_rtl.lst" r];
set data [read ${FILE}];
foreach f ${data} {
  echo "-------------------------------------------------------------";
  set file "${RTL}/${f}";
  echo "FILE: ${file}";
  vlog -work ${LIB} -vopt -sv -incr "${file}";
close ${FILE};
could it be called as following?
%> comp_rtl_lst (.RTL(./rtl/), .LST(./lst/), .UNIT(abc), .LIB(ABC))
Thank you!
