vinayelk
TCL script for bitstream generation
Hello everyone,
I am fairly new to PFGA programming and I only have the most basic knowledge about how to program my RTL source on to the board. I want to generate bitstreams for about 454 RTL sources which only slightly differ from each other and I want to automate this process using TCL scripts if its possible. Doing the same manually and waiting for the bitstream generation would probably take me over a week since the implementation takes about 21 minutes.
If anyone could help me out with this with any guides or steps to write a TCL script and use them on Vivado would be helpful.
hongh
You can try to export the tcl script file for creating the Vivado project by executing "write_project_tcl XX.tcl" in TCL CONSOLE of Vivado GUI.
Then you can add launch_runs commands in the generated tcl.
