Visitor cartercheng1
Tcl Command to get the current specified top module name
Hi, I want to know if any Tcl Command can get the current specified top module name Thanks a lot
Re: Tcl Command to get the current specified top module name
Hi  @cartercheng1 ,
Try this command    report_property -all [get_filesets sources_1]
And check the TOP property's value.
hemangd
Don't forget to give kudos and mark it as accepted solution if your issue gets resolved.
Hi  @cartercheng1 ,
hemangd
Observer sarman_1998
For anyone else who finds this, thanks to @hemangd, I ended up with this command.
get_property TOP [get_filesets sources_1]
Eric
And then I tried to use this in a tcl.post hook script.....
After some debugging, the TOP property is empty when get_property or report_property are run in the hook script.  I did some googling and am guessing this has something to do with project vs non-project mode but I haven't found a workaround.
@hemangd any suggestions?
Hi @sarman_1998
Can you try with tcl.post hook script of opt_design and check?
hemangd
Hi @hemangd
Things are getting stranger!
When I was testing this script i was using the following steps in the vivado GUI
  1. Reset implementation to previous step.  To go back from write_bitstream step.
  2. Change script file.
  3. run Generate Bitstream.
Using those steps, the TOP property was blank when the hook script ran.
However, when i run the full implentation, TOP is defined properly when the script runs, both at opt_design and also at write_bitstream.
Any ideas why the behavior is inconsistant?
   Eric
Historian
Historian
What are you trying to accomplish?
The concept of "filesets" doesn't exist (or at least doesn't consistently exist) at the level of the hook scripts; the filesets are part of the project management system, which only exists in the foreground process; the hook scripts run in the background processes in non-project mode (where the filesets no longer exist). There may be some exception when you run synthesis, since synthesis is a bit different.
But even if it does work in some cases, it is not "legal" and the behavior could change from version to version.
However, I do believe "current_design" does exist at the non-project/hook script level, so
get_property TOP [current_design]
might work...
Avrum
Thanks @avrumw
Works.
To answer your question I was trying to update the script to write the MCS after bitgen so that I didn't have to modify it with the top module name for each FPGA project.   For anyone interested, this is what I ended up with.
set top_name [get_property TOP [current_design]]
set up_list [list up 0x000000 [format "%s%s" $top_name ".bit" ]]
write_cfgmem  -format mcs -size 16 -interface SPIx4 -loadbit $up_list -force -file $top_name
There is probably a more eligant way to handle the options to -loadbit but my TCL skills are very rusty.
Thanks to @hemangd  also for their help.
Eric
