diptyajit
Tcl 'for' loop : issues with radix (Error 20-1474)
This is a followup on this question
http://forums.xilinx.com/t5/Vivado-TCL-Community/Automating-VIO-interaction-using-TCL-in-Vivado-2014-1/td-p/466740
Issue
I want to run a loop in tcl and use the loop variable as an argument in the 'set_property' command. However I keep getting an error which I have searched for, but cant figure out yet.
Code I use
for {set i 0} {$i < 2} {incr i} {
set vio_output $i
set_property OUTPUT_VALUE $vio_output [get_hw_probes probe_debug_read_select -of_objects [get_hw_vios hw_vio_2]]
commit_hw_vio [get_hw_probes {probe_debug_read_select} -of_objects [get_hw_vios hw_vio_2]]
The shell gives me this error
ERROR: [Designutils 20-1474] The hw_probe VIO value [0] has [1] value characters. The required number of value characters for radix [HEX], is [2].
Addendum
I understand the error, but I dont know how to solve it. I was under the impression that TCL uses strings to represent everything and there inherently should not be a concept of a radix.
Please note that
set_property OUTPUT_VALUE 02 [get_hw_probes probe_debug_read_select -of_objects [get_hw_vios hw_vio_2]]
OR
set_property OUTPUT_VALUE 50 [get_hw_probes probe_debug_read_select -of_objects [get_hw_vios hw_vio_2]]
works fine.
Tags (4)
vuppala
The issue is occuring because the output_value is set to hexadecimal.
You can change radix to binary, octal,...
See the page no. 78 of the following user guide: http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_1/ug908-vivado-programming-debugging.pdf
Vinay
diptyajit
Hello Vinay,
Yes, I understood that the issue is the radix, But I want to keep the hexadecimal radix, so I have to figure out a way to generate 'hex' values in the loop itself which feeds the set_property command.
Dip
vuppala
Try changing the i value to hexadecimal using the below command:
format %x $i
Vinay
diptyajit
Hello Vinay,
Thanks again for the prompt response. I read up on the format command, and realized what it does.  However, when I am doing this :
for {set t 0} {$t < 5} {incr t} {
set_property OUTPUT_VALUE [format %x $t] [get_hw_probes probe_debug_read_select -of_objects [get_hw_vios hw_vio_2]]
I keep getting the same error. I have tried several variations of this, including something like
set dummy [format %x $i]
set_property OUTPUT_VALUE $dummy [get_hw_probes probe_debug_read_select -of_objects [get_hw_vios hw_vio_2]]
but i still keep getting the same error. Any ideas on why ?
vuppala
Try this:
format %x $t
Vinay
diptyajit
Same issue persists. I have also tried
for {set z [format %x 0]} {$z < [format %x 5]} {incr z} {
format %x $z
set_property OUTPUT_VALUE [format %x $z] [get_hw_probes probe_debug_read_select -of_objects [get_hw_vios hw_vio_2]]
 but to no avail
vuppala
Typo mistake. Try this:
set i [format %x $t]
set m $i
set_property OUTPUT_VALUE $m [get_hw_probes probe_debug_read_select -of_objects [get_hw_vios hw_vio_2]]
Vinay
diptyajit
It looks like you are setting variable i as a hex format of . That is similar to what I have been trying.
Then you set another variable as . I did not really understand what is gained by this extra variable assignment.
Anyways, I tried the same and this is what my log looks like
# set fp [ open vio_data.dat w+ ]
# for {set t 0} {$t < 2} {incr t} {
#     set i [format %x $t]
#     set vio_output $i
#     # setting VIO output to the design
#     set_property OUTPUT_VALUE $vio_output [get_hw_probes probe_debug_read_select -of_objects [get_hw_vios hw_vio_2]]
#     commit_hw_vio [get_hw_probes {probe_debug_read_select} -of_objects [get_hw_vios hw_vio_2]]
#     #refreshing and reading vio_inputs
#     refresh_hw_vio [get_hw_vios {hw_vio_2}]
#     set vio_input [get_property INPUT_VALUE [get_hw_probes probe_debug_read_data]]
#     puts $fp "vio_select $vio_output vio_data $vio_input"
    while executing
"rdi::set_property OUTPUT_VALUE 0 probe_debug_read_select"
    invoked from within
"set_property OUTPUT_VALUE $vio_output [get_hw_probes probe_debug_read_select -of_objects [get_hw_vios hw_vio_2]]"
    ("for" body line 9)
    invoked from within
"for {set t 0} {$t < 2} {incr t} {
    set vio_output $i
    set_pro..."
    (file "/var/lib/jenkins/workspace/board_program/debug_vio.tcl" line 34)
INFO: [Common 17-206] Exiting Vivado at Wed Jun  4 16:22:07 2014...
diptyajit
To clarify, I still get the same error as before. This is not resolved yet.
avrumw
Guide
Guide
The "format" command takes C-style formatting strings.
The %x format says "put it in hex"
The %2x format says "put it in hex and use two characters", but unused leading characters will be spaces
The %02x format says "put it in hex and use two characters, with leading 0's to fill in the space"
So, if you use
[format %02x $i]
it should work.
Avrum
