gatorbite5
Updating BRAMs within an encrypted bitstream with a .elf file Vivado 2013.4
I have an encrypted design that I am trying to update the BRAM contents of the .bit file with a .elf file.  I have found AR#22364 on the issue, but I am having some issues with the TCL command since I am new to Vivado and producing encrypted bitstreams.
I placed the .elf file in the root folder of my Vivado project and then attempted to run the below TCL command after I had opened the project:
set_property MEMDATA.ADDR_MAP_CELLS {system_i/microblaze_1} [get_files my_elf.elf]
I get the following Warning and Error messages in the TCL console and believe that I am not placing my .elf file in the proper location:
WARNING:  [Vivado 12-818] No files matched 'my_elf.elf'
ERROR:  [Common 17-55] 'set_property expects at least one object.
Where should the .elf file be placed?  Is there anything else with this process that I am doing wrong in order to update .bit file so that I can then re-run write_bitstream to produce my final encrypted bitstream?
Thanks in advance for the help!
gatorbite5
I believe I solved my issue by first adding the .elf as a design source.  Once I had done this, I went to Tools > Associate ELF Files...  in order to select my .elf file as the desired file for the microblaze component.
I then ran the TCL script I initially was asking for help with, without using the full file path, and the TCL appeared to execute without any issues.   Then I re-ran only the Write_Bitstream process.
Once programmed to my SPI Flash, everything works properly!
smarell
Community Manager
Community Manager
Please specify the location of the elf file as in
set_property MEMDATA.ADDR_MAP_CELLS {system_i/microblaze_1} [get_files C:/Proj_Dir/impl_1/my_elf.elf]
Basically, if the elf file resides in C:/Proj_Dir/impl_1/ location (for example), you can provide the entire location.
This will resolve your issue.
gatorbite5
smarell,
Thank you for your reply, however that did not solve my issue.  I still received the same Warning and Error messages that I stated in my initial post.
vuppala
Try out these steps:
1. Open project
2. In Tcl console, run the command "pwd" without quotes
3. If you are not in the project directory, navigate to project directory where my_elf.elf was present using cd command
4. then run the command: set_property MEMDATA.ADDR_MAP_CELLS {system_i/microblaze_1} [get_files my_elf.elf]
gatorbite5
ajkolla
Hi Sir,
I am working on ARTIX7  FPGA, on which I am developing a data acquisition system with MicroBlaze. I am facing problem in generating encrypted .bit(mcs) file by merging .bit( generated in vivado) file and .elf( generated by SDK) file.
I have studied your post and tried implementing it but it didn’t work.
can you please help me in implementing it.
