Visitor aspenlogic
Using Vivado TCL command show_schematic on the root of the design
Problem
I was looking for a scriptable way to generate the top schematic after running a script.
I find it curious that show_schematic requires an object but no command will return the object for the root of the design. I expected either show_schematic with no argument (or the empty string {}) should show the schematic for the current instance (as reported by current_instance) when it is the root or there should be a command like get_cells / that returns an object for the root..
Solution
Hence, to view the top level of the design, UG835's entry for show_schematic indicates that the TCL command show_schematic [get_nets] is required. This works but seems counter-intuitive. Not to mention non-orthogonal when you consider that show_schematic [get_cells pcie_interface/transaction/ctr] would show the schematic for that instance path in the design. Meaning show_schematic [get_cells /] should work as expected to show the schematic for the top level (using a conventional indication of a solitary slash as the root.)
Questions
I have that now, yet my curiosity as to why get_cells / does not work as expected is unsatisfied.
Any thought leaders out there have an explanation of this (apparent) inconsistency?
What am I missing here?
Is there a subtlety to wanting all instances paths to be relative to avoid giving meaning to a leading slash?
Why doesn't show_schematic [current_instance] work when the current instance is the top of the netlist/design?
Postscript
For those reading this post, try
show_schematic [get_pins]
show_schematic [get_ports]
show_schematic [get_cells]
The first two produce surprisingly useful pictures. The last one appears to produce a schematic of the entire design. Yet, in some cases nets were not completely rendered and ports were missing!
ASPEN LOGIC, INC.
By: Timothy R Davis, President
