VHDL Conditional compilation
Can we have conditional compilation (build differs in logic and I/O pin mapping) as a single fpga configuration file.
FPGA Family: Artyx 7
Coding : VHDL
I have used the conditional compilation technique (which differs in logic using 'ifdef) in verilog. Since VHDL doesnt have maro-languages, how can we implement the same.
Many Thanks
Sruthi
If you want a different pinout you can import the XDC as unmanaged and then you can include any tcl in it. Note. Vivado cannot modify unmanaged tcl files.
If {$variant eq "variantA" } {
  #pins for variant a
} else {
  #pins for variant b
This along with generics allows you to easily control what you're building.  I highly recommend scripting your build flow,  then you can easily choose what to build from the command line.
You cant ,
A configuration file defines the working of the FPGA,
the configuration file is made from your HDL,
so if you change the HDL you get a different configuration file.
no matter if you do that in VHDL or Sverilog or Python et all,
There is the option in FPGAs to have multi boot,
but that's a different thing to what your describing using #defines.
many example son the web, but this gives you the idea
https://www.xilinx.com/support/documentation/application_notes/xapp1257-multiboot-fallback-spi-flash.pdf
And what do you want to do in a macro language in VHDL ?
You can use generics and generates to specify what exist inside an FPGA build
Please confirm can we use the same method even if few I/O pin differs..
I am not trying for the multiboot option in FPGA, instead i need a conditional compilation(both RTL and xdc file) technique.
I have tried conditional compilation in verilog RTL code using  'ifdef as in below syntax .
`ifdef <FLAG1>
       // Statements
`elsif <FLAG2>
      // Statements
`else
     // Statements
`endif
Please advice is it possible to achieve the same logic in VHDL.
The equivalent in VHDL is
If generate / else generate
ensure you have 2008 turned on
  #pins for variant a
} else {
  #pins for variant b
With tkl you can do anything,
but
You still cant have two different designs in the one configuration file which is what you asked for.
The following code maybe help you:
LABEL_Simulation_Only_IO:
if (Report_Enable_IO = '1') generate
begin
Report_Unit_1 : Report_Unit
generic Map(
Port Map(
end generate;
