Observer uramashi2
Vivado 2018.1 non-project DDR4 IP intergration.
Hi.
Nowdays, I am building tcl script on the non-project base. But one thing makes me crazy.
that is DDR4 Xilinx IP.
I use the VCU1525 development kit and vivado 2018.1.
vivado tool works well by "generate_target" command.
while synthesis the module, vivado tool send message to me "generated XDC of IP path is wrong"
but when I build tcl script on project base, all things is fine.
Is there anyone who share non-project script?
please help me.
Re: Vivado 2018.1 non-project DDR4 IP intergration.
Hi @uramashi2
Refer  below link for scripting in non-project flow using IP, Chapter 4. Hope it helps:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug939-vivado-designing-with-ip-tutorial.pdf
Rohit
@uramashi2
Can you share the complete message?
Chapter 4 in below UG covers the non-project mode with example:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug892-vivado-design-flows-overview.pdf
--Syed
