Voyager
Voyager
Vivado 2018.3 terminates unexpectedly on start_gui
Vivado% start_gui
java.lang.reflect.InvocationTargetException
at java.desktop/java.awt.EventQueue.invokeAndWait(Unknown Source)
at java.desktop/javax.swing.SwingUtilities.invokeAndWait(Unknown Source)
at ui.PlanAhead.i(SourceFile:1505)
at ui.PlanAhead.eq(SourceFile:569)
at ui.PlanAhead.ex(SourceFile:881)
at ui.PlanAhead.a(SourceFile:1609)
at ui.frmwork.b.l.d(SourceFile:41)
at ui.frmwork.HTclEventBroker.i(SourceFile:255)
at ui.frmwork.HTclEventBroker.fireTclEvent(SourceFile:350)
Caused by: java.lang.IllegalArgumentException: Window must not be zero
at java.desktop/sun.awt.X11.XAtom.checkWindow(Unknown Source)
at java.desktop/sun.awt.X11.XAtom.getAtomData(Unknown Source)
at java.desktop/sun.awt.X11.XToolkit.getWorkArea(Unknown Source)
at java.desktop/sun.awt.X11.XToolkit.getInsets(Unknown Source)
at java.desktop/sun.awt.X11.XToolkit.getScreenInsets(Unknown Source)
at java.desktop/sun.java2d.SunGraphicsEnvironment.getUsableBounds(Unknown Source)
at java.desktop/sun.awt.X11GraphicsEnvironment.getXineramaWindowBounds(Unknown Source)
at java.desktop/sun.awt.X11GraphicsEnvironment.getMaximumWindowBounds(Unknown Source)
at com.jidesoft.utils.PortingUtils.getLocalScreenBounds(Unknown Source)
at com.jidesoft.utils.PortingUtils.ensureVisible(Unknown Source)
at com.jidesoft.action.DefaultDockableBarManager.m(Unknown Source)
at com.jidesoft.action.DefaultDockableBarManager.f(Unknown Source)
at com.jidesoft.action.DefaultDockableBarManager.resetToDefault(Unknown Source)
at com.jidesoft.action.DefaultDockableBarManager.a(Unknown Source)
at com.jidesoft.action.DefaultDockableBarManager.loadLayoutFrom(Unknown Source)
at com.jidesoft.swing.AbstractLayoutPersistence.loadLayoutDataFrom(Unknown Source)
at com.jidesoft.swing.AbstractLayoutPersistence.loadLayoutData(Unknown Source)
at ui.q.ag(SourceFile:137)
at ui.bm.bK(SourceFile:960)
at ui.bm.<init>(SourceFile:161)
at ui.de.a(SourceFile:1396)
at ui.de.run(SourceFile:1359)
at java.desktop/java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.desktop/java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.desktop/java.awt.EventQueue.access$500(Unknown Source)
at java.desktop/java.awt.EventQueue$3.run(Unknown Source)
at java.base/java.security.AccessController.doPrivileged(Native Method)
at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
at java.desktop/java.awt.EventQueue.dispatchEvent(Unknown Source)
at ui.frmwork.b.d.dispatchEvent(SourceFile:88)
at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.desktop/java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.desktop/java.awt.EventDispatchThread.run(Unknown Source)
at ui.PlanAhead.eq(SourceFile:585)
Failed to open 'Vivado application'. Please check your system resources and launch again.
-------------- Yes, I do this for fun!
Re: Vivado 2018.3 terminates unexpectedly on start_gui
Hi @hpoetzl ,
This is a known issue, previously reported too. Are you using Ubuntu, if yes, then check below:
https://forums.xilinx.com/t5/Installation-and-Licensing/Vivado-2018-3-won-t-launch-on-Ubuntu-18-04-java-lang-reflect/td-p/934610
The problem is caused by:
You have multiple monitors, right?  Turn all but 1 off when starting vivado up (afterwards startup you can turn them back on).  You can unplug them, but you can also open up "configure display settings" (generally an icon that looks like a monitor in your taskbar tray), then select each monitor and click the "off" button.
Raj.
Voyager
Voyager
Hello Raj,
Yes, I have multiple monitors.
Unplugging or even disabling all but one every time I start up Vivado is not really an option as this happens many, many times a day.
What causes this issue and when will it be fixed?
What Vivado versions are affected by this?
Thanks in advance,
Herbert
Newbie sdfhmbg
I've just run into the same issue. As a workaround i have installed Xephyr and now run Vivado in a nested x-server with the following little script:
#!/bin/bash
Xephyr :1 -screen 2560x1400&
DISPLAY=:1
openbox&
source ~/Data/fpga_stuff/Xilinx/Vivado/2018.3/settings64.sh
vivado
Maybe this is useful to someone. One big disadvantage though is that there is no shared clipboard.
Visitor blumeraluna
Thanks for the Xephyr suggestion. That works for me with 2019.1. I am also successfully exchanging clipboards between Xephyr and the top level X server by using xclipsync on github: https://github.com/apenwarr/xclipsync
