Vivado.exe timeout
Hello;
I have a problem with the start-up of Vivado 2018.3 varsion, when i start vivado an error message is showing, because of the timeout of vivado.bat, and when i launch vivado.bat with commande prompt an ahor error message is showing. Vivado.exe application does not exist in Win4.o file, the full path is : C:\Xilinx\Vivado\2018.3\bin\unwrapped\win64.o and when i go there i do not find the vivado.exe application, so what can i  do?
Thank you.
Re: Vivado.exe timeout
Hi @amhamj ,
Try rebooting and if it doesn't solve the problem, then uninstall and re-install Vivado.
Also please check this AR#:
https://www.xilinx.com/support/answers/57386.html
Raj
Hi @amhamj ,
Raj
