Vivado internal exception error in HW Manager
Hello Dear All,
I am getting the 'Vivado internal exception error' in the Hardware Manager when I right-click on the ila cores. The full explanation for the error is in the following:
# This report is an indication that an internal application error occurred.
# This information is useful for debugging. Please open a case with Xilinx.
# Technical Support with this file and a testcase attached.
java.lang.NullPointerException
at ui.views.c.n.e.tX(SourceFile:101)
at ui.views.c.n.e.bg(SourceFile:36)
at ui.frmwork.a.dSk(SourceFile:66)
at ui.d.ap.eee(SourceFile:537)
at ui.d.bw.init(SourceFile:74)
at ui.d.bw.<init>(SourceFile:55)
at ui.d.ap.<init>(SourceFile:140)
at ui.views.v.r.b(SourceFile:204)
at ui.b.c.b.v.mousePressed(SourceFile:645)
at java.awt.AWTEventMulticaster.mousePressed(AWTEventMulticaster.java:280)
at java.awt.AWTEventMulticaster.mousePressed(AWTEventMulticaster.java:279)
at java.awt.Component.processMouseEvent(Component.java:6530)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
at ui.utils.i.j.ag.processMouseEvent(SourceFile:510)
at java.awt.Component.processEvent(Component.java:6298)
at java.awt.Container.processEvent(Container.java:2236)
at ui.utils.i.j.ag.processEvent(SourceFile:619)
at java.awt.Component.dispatchEventImpl(Component.java:4889)
at java.awt.Container.dispatchEventImpl(Container.java:2294)
at java.awt.Component.dispatchEvent(Component.java:4711)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4888)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4522)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466)
at java.awt.Container.dispatchEventImpl(Container.java:2280)
at java.awt.Window.dispatchEventImpl(Window.java:2746)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:80)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:90)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue$4.run(EventQueue.java:729)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
at ui.frmwork.b.d.dispatchEvent(SourceFile:76)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
The screenshot of the error is attached. When I say continue in the error window, it continues with normal functionality.
Does anyone have an idea on this error Why I am getting?
Re: Vivado internal exception error in HW Manager
Hi samid@sensobright.com ,
Can you please try using the latest version of Vivado 2018.3 and check if you are still facing the issue.
Thanks & Regards,
Sravanthi B
Can you please let us know which version of Vivado are you using and on which OS?
How many ILA cores do you have in your design? Does this issue occur when you right click on all the ILA cores you have in your design?
Thanks & Regards,
Sravanthi B
I am using 2017.4 and Win10. There are 4 ila cores. This error occurs when I right click on only one.
Thanks & Regards,
Sravanthi B
