luoxi213
Want a complete non-project example, including emulation with C
I now want to implement a non-project design and be able to import it into the SDK and compile emulation with C files.
I want to know how to write the source, constraint, simulation file and C language file in this process?
Can the above files be generated in the IDE and then imported into the Tcl interpreter in non-project mode for synthesis - >Implementation - >Generate bitstream - >Launch SDK->Import C language file this way to achieve?
Is there a complete example that I can refer to, preferably one that teaches me how to write those files, not just the steps in UG894?
thank you
hemangd
@luoxi213 Check this page 82 onwards https://www.xilinx.com/support/documentation/sw_manuals/xilinx2020_2/ug892-vivado-design-flows-overview.pdf
hemangd
hemangd
hemangd
