What is the value of prefix for report_failpast
In ug1292, it describes that
When you use the -detailed_report <prefix> option, report_failfast generates additional detailed reports for each check that does not meet the guideline (except for resource utilization checks). Review each of the following reports:
 <prefix>.TIMING.rpt: Detailed Methodology TIMING-* violations
 <prefix>.AVGFO.rpt: Average Fanout for modules bigger than 100,000
 <prefix>.HFN.rpt: Non-FD high fanout net (HFN) driving more than 10,000 loads
 <prefix>.DONT_TOUCH.rpt: List of cells/nets with DONT_TOUCH property set
 <prefix>.timing_budget_LUT.rpt: Detailed timing paths failing the LUT budgeting
 <prefix>.timing_budget_LUT.rpx: Detailed timing paths failing the LUT budgeting (Vivado IDE interactive report)
 <prefix>.timing_budget_Net.rpt: Detailed timing paths failing the net budgeting
 <prefix>.timing_budget_Net.rpx: Detailed timing paths failing the net budgeting (Vivado IDE interactive report)
What does the prefix mean? I try to get the value by using -help, but nothing explains. When I use
xilinx::design_utilities::report_failfast -detailed_report timing_budget_Net.rpt
It produces the same report as using the tcl below.
Could anyone give me a clue?
Hi, @araongao2015 ,
The prefix option for -detailed_reports will add the prefix as you define for the generated report:
It will help you differentiate the reports for different deisgns.
Hi, @araongao2015 ,
