Write TCL misses Verilog header files
Vivado 2018.3, project created from the GTH wizard.
When writing the TCL to recreate the project, it misplaces the verilog header file:
gtwizard_ultrascale_0_example_wrapper_functions.v
and adds it as a simulation file, what causes an error when building the recreated project.
Does anyone know how to manually change that on the TCL?
Re: Write TCL misses Verilog header files
Adding this seems to do the trick:
set_property file_type {Verilog Header} [get_files gtwizard_ultrascale_0_example_wrapper_functions.v]
It would be better to have real improvements in the tools instead of bundling them and coming with new fancy names. Some of us realize things.
Hi, @satguy ,
In 2019.2 Vivado, the issue seems to be corrected:
set file "imports/gtwizard_ultrascale_0_example_wrapper_functions.v"
set file_obj [get_files -of_objects [get_filesets sources_1] [list "*$file"]]
set_property -name "file_type" -value "Verilog Header" -objects $file_obj
Good to know
