XDC file format .. pre compiler
Been hacking a lot of xdc files recently,
so one pin could be
set_property PACKAGE_PIN AB5 [get_ports EXP_IOWR]
set_property IOSTANDARD LVCMOS18 [get_ports EXP_IOWR]
set_property SLEW SLOW [get_ports EXP_IOWR]
set_property DRIVE 4 [get_ports EXP_IOWR]
Was wondering, how hard can it be ? to write a pre compiler,
so one could in a file wirte
set_property [get_ports EXP_IOWR]  PACKAGE_PIN=AB5, IOSTANDARD=LVCMOS18, SLEW=SLOW, DRIVE=4
and have a tcl script , say pre.tcl that convert the abovr file to the xdc format that xilinx wants ?
does that sound totaly crazy as a chrismas project ?
the driving force is, when we change pin names,
   which happens to oftern for my liking but , not my call. its only one line to change
Any thought
have a great christmas,
Guide
Guide
You can already do this with the -dict option
set_property -dict {PACKAGE_PIN AB5 IOSTANDARD LVCMOS18 SLEW SLOW DRIVE 4} [get_ports EXP_IOWR]
Avrum
Guide
Guide
Avrum
Ah the power of TCL,
yes the dict option would solve the multi line thing,
thanks
Guide
Guide
This isn't really Tcl. The format and options of the set_property command are specified and implemented by Xilinx - they are a part of XDC. Don't quote me on this, but I think the -dict option was a fairly late addition to the command syntax; I don't think earlier versions of Vivado (like in the 2012 time frame) supported this option...
So, not "Ah the power of Tcl", but "Ah the power of Vivado"!
Avrum
power of Vivado...
wont get into that....
out of interest, dict was added to later tcl, and I guess this is a vivado hook into that,
http://www.wellho.net/mouth/3614_Tcl-dicts-a-tutorial-and-examples.html
I'm sorry to "hijack" this thread, but I think it's relevant.
Working on DDR design, I want to set:
            - INPUT/OUTPUT_IMPEDANCE value for an I/O pin let's say 40/40 ohms
            - PRE_EMPHASIScalue  for an IO pin let's say 240 ohms
Read the document ug945-vivado-using-constraint-tutorial, there is nothing about these, what is the tcl syntax and keyword would be?
Something like these:
          - set_property keyword_xx RDRV_40_40 [get_ports {DDR4_DQ[0]}]
          - set_propery  keyword_xx RDRV_240 [get_ports {DDR4_DQ[0]}]
Thanks you
Searched ug903 too..
Guide
Guide
First - you should have started a new thread for this - they really aren't related. You should also tell us what family you are working with - from this thread and from your posting, there is no way to tell that you are asking about UltraScale (I assume) - this would probably have been best posted to the UltraScale forum.
That being said, the answer is in the UltraScale I/O User Guide UG571. The properties for the I/O structure are listed there, including an example as to how to use them.
For the output impedance, the property is OUTPUT_IMPEDANCE, as shown on page 65 of the user guide (v1.5), including an XDC example on the next page:
set_property OUTPUT_IMPEDANCE value [get_ports port_name]
The pre-emphasis is on p. 68
set_property PRE_EMPHASIS value [get_ports port_name]
Avrum
Advisor
Advisor
Can the IOSTANDARD for an entire bank be set at once, instead of specifying it for each pin?
I've found this tcl line somewhere, but it doesn't seem to work in Vivado 2015.2.1
# Bank 33, Vcco = 3.3V
set_property IOSTANDARD LVCMOS33 [get_ports -of_objects [get_iobanks 33]];
