XDC indexing generated cells
I'm trying to area constrain a couple hundred FIFOs that are all generated instances as smaller groups of FIFOs. How can I add a range of instances to a pBlock other than manually duplicating the constraint and changing the index number?
For example I would like to replace this:
add_cells_to_pblock [get_pblocks pblock_0_11] [get_cells Code_inst/FIFO_GEN[0].fifo_inst]
add_cells_to_pblock [get_pblocks pblock_0_11] [get_cells Code_inst/FIFO_GEN[1].fifo_inst]
add_cells_to_pblock [get_pblocks pblock_0_11] [get_cells Code_inst/FIFO_GEN[11].fifo_inst]
With something more like this:
add_cells_to_pblock [get_pblocks pblock_0_11] [get_cells Code_inst/FIFO_GEN[0 to 11].fifo_inst]
Is this possible?
Dan
Guide
Guide
Loops in "XDC" files are not supported. They are supported in "Unmanaged constraint" files - in project mode you put the constraints in .tcl files (not .xdc files), and in non-project mode you source the .tcl file or in newer versions use "read_xdc -unmanaged"
However, this is not necessarily the best way to go. There are some complexities with unmanaged constraint files, and parsing the XDC file will be slower - in XDC you always want to minimize the operations that access the design database (since they take time).
While its not perfect, you can use the regular expression wildcarding format. All the "get_" commands (including get_cells) have the option -regexp. This changes how wildcarding in the name is interpreted. Without the -regexp, the wildcarding uses the simple "glob" style wildcards - these are probably too simplistic to represent numerical ranges.
However, with the -regexp option, the command uses the full "Regular Expression" syntax. Here you have more capability. Even with -regexp you can't directly represent a number range (regexp is string based, not numerical), but you can construct regular expressions that will do what you want. A quick search of the web turned up this web page that helps you construct number ranges using regular expressions. This should work in an XDC file...
Avrum
@dcwhitehead,
Not sure but can you try using for loop:
for {set i 0} {$i < 12} {incr i} {
add_cells_to_pblock [get_pblocks pblock_0_11] [get_cells Code_inst/FIFO_GEN[$i].fifo_inst]
Syed
@dcwhitehead,
Seems like loops are not supported in XDC from the below link:
http://www.xilinx.com/support/answers/59134.html
however it also mentions a workaround of applying constraints in form of loops.
Syed
Guide
Guide
Avrum
Wildcards are also suported.  You can use [*] to grab all geneated instances of the same name.
Ah, sorry. I misread the initial question. I see why this does not work for you. Please ignore.
Avrum,
Thanks for the input! Regular expressions should work for me. The following example code does exactly what I need.
[get_cells -regexp {Code_inst/FIFO_GEN\[(1[0-1]|[0-9])\]\.fifo_inst}]
-Dan
